Top Spark accessories for June 2019 (by DDH)
msinger
DJI Drone Expert
Approved Vendor
Harrisburg, PA (US)
spark-help.com
I've compiled a list of the top Spark accessories for June 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you're looking for some new accessories to add to your kit, this list will give you an idea of what other Spark owners are buying and using.
SanDisk 32GB Micro SD Memory Card
Notable features:
  • U3 memory card
  • Fast enough to record any type of photos/video produced by the Spark
  • Plenty of storage space to capture all of the needed photos/video
More details can be found here on Amazon.
UZOPI Foldable Tablet/Phone Mount
Notable features:
  • Made of aviation aluminum-alloy
  • Able hold a mobile device between the width of 4-12 inches
  • Mount can be swiveled sideways to hold a phone
  • Hole at base to attach the included lanyard
Homga Landing Pad
Notable features:
  • 30 inches wide
  • Made of a waterproof nylon material
  • Includes stakes to ensure the landing pad stays in place
  • Fold up and store in the included storage bag
More details can be found here on Amazon or here in the DJI Store.
SKYREAT Foldable Tablet/Phone Mount
Notable features:
  • Hole at base to attach a lanyard
DJI Spark Battery
Notable features:
  • Created, designed, and extensively tested by DJI
  • Guaranteed to work well with your Spark since the battery is an OEM DJI accessory
Threeking Parabolic Signal Booster
Notable features:
  • Boosts the remote controller signal to increase its range
  • Folds closed for storage
DJI Spark Props
Notable features:
  • Guaranteed to work well with your Spark since the props are an OEM DJI accessory
DACCKIT Carrying Case
Notable features:
  • Tough and durable hard outer shell
  • Carry with the adjustable shoulder strap or side carry handle
  • Can hold the Spark, remote controller, 5 batteries, charger, charging hub, and other small accessories
Fstop Labs Foldable Tablet Mount
Notable features:
  • Made of high impact ABS plastic
  • Attach and detach within seconds
  • 360 ball joint allows the tablet to be adjusted for better visibility
  • Folds into a compact form factor for storage
LEOBRO Accessory Kit
Notable features:
  • Lock the gimbal in place and protect the camera with the gimbal lock and cover
  • Protect the remote controller sticks while in storage with the remote controller stick protector
DJI Battery Charging Hub
Notable features:
  • Charges 3 batteries at the same time
  • Recharge 3 batteries in 90 minutes
  • Powered by the Spark battery charger
  • Guaranteed to work well with your Spark batteries since it's an OEM DJI accessory
DJI Spark Prop Guard
Notable features:
  • Prevent the props from making contact with people or objects mid-flight
  • Guaranteed to work well with your Spark since the prop guard is an OEM DJI accessory
RC GearPro Battery Charging Hub
Notable features:
Hermitshell Cases
Notable features:
  • Separate hard shell cases to store Spark, remote controller, and batteries
  • Hard outer shell and soft interior
  • Protects Spark and accessories from being bumped or scratched
SKYREAT Foldable Tablet/Phone Mount (New Design)
Notable features:
  • This upgraded version is more durable since the plastic tightening ring has been replace with a metal ring
  • Store the mount and lanyard in the included storage bag
Kuuqa Accessories Kit
Notable features:
  • Protect the props when in flight with the prop guard
  • Shield the camera from the sun and protect the camera with the lens hood
  • Protect your fingers when hand catching with the finger guard
Deyard Carrying Case
Notable features:
  • Portable and lightweight
  • Hard outer shell to protect the contents
  • Can hold the Spark, remote controller, 3 batteries, charger, and other small accessories
RCstyle Parallel Battery Charger
Notable features:
  • Charges 4 batteries simultaneously in about 60 minutes
  • Able to also charge 2 USB devices
  • Can also be powered via a car cigarette lighter charger
PGYTECH Tablet/Phone Mount
Notable features:
  • Able hold a mobile device between the width of 4-10.5 inches
  • Swivels on a ball joint to adjust the angle of the mobile device
  • Quick-release thumb screw allows you to attach and remove the mount quickly
Yx Parallel Battery Charger
Notable features:
Vnet65
