ATTI Mode Help
Sparky786
Hi people. In mid flight I have been getting Atti mode about 63m in the sky. So this has been going on about the last 3 flights I had, pre flight checks were all good to go.
Any idea why this has been happening.
I'm in London and have been flying in a BIG open field with planes going by.
Tmx
You should receive a warning from spark in a no fly zone , but if planes are going by.. how close?.
CAA rules specify distance from airports, buildings etc.
Still if you're happy. Atti mode usually results from compass interference.
There pretty high from where I am..i only get caution which go away after a few ticks
Sounds good
How many sats counted at take off? Do they disappear as you fly? Check sensors/gyros/compass are green in advanced settings before you fly..
There will be logs of all this in your phone/tablet, and you can post them on line where more experienced pilots can decipher them, either in this forum or the DJI version.
Hope this helps.
Sounds good
Hope this helps.
Everything shows fine when flying..atti mode only last about 10sec then it's fine
Could be several things. Satellite count, compass error. Only examination of flight log likely to pin it down I think.
This is dji's video on it, but there are many others on you tube.
Reactions: Donny and Sparky786
matthias xerri
