Battery N/A
I haven't noticed on mine.
Do you fly with an OTG cable?
In the past versions of DJI Go4, the cable "worked" but with limitations such as no battery info on Android devices.
I haven't flown with a cable for a while and I thought newer versions of the app "fixed" it?
Reactions: Hddeuce03
I experienced that on the App mod (red one) when the cable disconnected. It was all that happened before the battery came back a while after. It's like the OTG was only used to pass the info about the battery.
Since then I don't use the OTG cable anymore.
I experienced a similar event. Check my post in the help forum. I was not using an OTG.
