Thanks for the link. In your post you mentioned topping off a battery while flying another. Does this battery pack connect to the battery or only to the Spark? Thanks again.just throw in my .02c, I was in europe a few weeks ago and didn't bring the charging hub for the spark and solely used the micro USB to charge the 2 batteries that I brought with me. on the rare occasion that I was not close to an AC adapter, I would use my Aukey 10k Mah battery pack to charge the batteries and I have to say, I was very impressed with this device. I was able to not just charge the spark but also my iphone and my global wifi hotspot and it still had some juice left. This is a good idea when you're flying out somewhere and want to top off the battery while flying another..... here's a link to that battery pack https://www.amazon.com/gp/product/B01JIYWUBA/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Cheers!
I do the same except I only have a 120W inverter but it still charges 3 batteries without a problem. USB charging is still handy as hell when away from the car for a while but so much quicker using the inverter plugged into the car.If you have a car, you can plug a 150w (with peak power 300w) inverter as power source for charging hub. Mine is successfully charge 3 batteries using this method.
I just bought this one: https://www.amazon.com/gp/product/B019IFIJW8/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1any suggestions?
Hi, What is the charging time using the converter to charge 3 batteries and controller? About the same as plugged into ac outlet at home? Will the inverter do any damage to batteries, controller?I do the same except I only have a 120W inverter but it still charges 3 batteries without a problem. USB charging is still handy as hell when away from the car for a while but so much quicker using the inverter plugged into the car.
