Can someone help explain?
Damien88
User stick command error 1. Unit was in P-GPS mode and was responsive to RC input; 2. At t=2m09s, relative height=2.5m, unit recorded external impact, then rolled over and fell. 3. User commanded full stick decend and full stick rotation before the impact, avoidance system wont detect object if its not facing the object, customer rotate the drone before impact. Incident date: Incident GPS location: Conclusion: User stick command error. Impact in air. [Non warranty Repair]
Can someone explain this in laymen terms? Just heard from DJI. What I don’t understand is when it’s rotating and going down this makes the drone go forward into a house? I’m very confused.
Layman’s speak: you crashed it. Full decent and rotated it so it crashed from the rear. No sensors back there.
Yes, apparently already in foward flight. Even when inputting new commands, it was just too late to stop its foward momentum. Sorry about your crash. Just have it repaired and try again.
bashirul
