If you're speaking about the RC...while charging there are LED dots that light up while charging.is there anyway to see if the controller is charging? The miniUSB socket is very tight and I can't tell when it's working or not.
Thanks and yes I did mean the remote.If you're speaking about the RC...while charging there are LED dots that light up while charging.
Make sure that you're not forcing the mini USB into the RC...if I'm not mistaken it can only go in 1 way. Secondly, no LEDS will be displayed when fully charged.Thanks and yes I did mean the remote.
As I though the mini-USB is sooooo tight it's not connecting as no LEDs light up when it's plugged in
Hmm...Mine are very close to the bottom, but not flush.Thanks for that. As I thought actually.
Just looking into the socket on the controller the 'male' pins are flush with the bottom of the socket so no chance that they can connect with the lead
Thanks Chap. It appears mine is faulty - first time user and doesn't work out of the boxAs aviscomi said, it can enter in the RC connector only in one orientation even if the connector on the RC is rectangular.
if you just use the cable supplied and the correct side up you should be good to go
Your using a Lightening Cable (Apple connector). The controllers port is a microUSB. Stop trying to force the wrong cable in there, or you'll likely break the port and have to return it for a replacement controller.I'm having the same issue I have the controller it came with a small black Cable when plugged in no lights light up blinking to show charging . The cable doesn't seem to fit very well In the port??
That's a lightening cable. Lightening cables do not fit into Micro USB portsI'm having the same issue I have the controller it came with a small black Cable when plugged in no lights light up blinking to show charging . The cable doesn't seem to fit very well In the port??
