Crashed and broke arm
Jntrees
Hey guys,
I need my Spark repaired already after a week of owning. I hit my house doing a spiral shot and broke an arm.
What can I expect to pay from DJI? Do you think there are better options?
Thanks guys.
If you don't have the refresh or don't want to pay for repairs and are good at technical repairs, you could do it yourself buy purchasing a new frame for about $25 and transfer everything over?
There's a few YouTube videos on a Spark teardown to guide you along.
Not too interested in doing it myself. There are parts to solder I believe and I've never done that.
I broke my frame clean off at the motor and repaired it with 5 ton epoxy. It is rock solid. I bought a new frame just in case the repair starts to fail, but so far there are no signs of that. I an pretty handy with repairs, but after watching that video, I am in no hurry to replace the frame.
What kind of glue did you use?
This happened to me. I did not have insurance. Guess I had it less than a month...
Broke the motor clean off, wires dangling... I thought about trying to repair myself but didn't.
I opened up a service request with DJI and sent it in for repair, a place in Virginia.
They replaced the body and a set of propellers.
Fortunately the Spark has been great since.
Cost me $157 in total.
I used the only thing that I had at the time: super glue.
Ouch... That's a bit expensive. It will be an expensive lesson to learn I guess.
Odd, DJI quoted me $91 for the same repair.
What's with the labor rate?
1/2 hour = $30.
1 hour = $65.
o_O
That's not bad. If someone on this forum did repairs for a bit cheaper, they could make some good money. I've sent mine in today so I'll be good on this repair. Maybe I'll try it myself in the future.
If you are competent at desoldering, it shouldn't be too hard.
What I noticed from mine, is all arms have 3 wires going through them, all soldered to the LED modules at the end of the arms. To replace the frame, you need to desolder all of those connections to thread the wires through the arms, then re-solder them. Careful work for sure.
Definitely some research is needed. Sounds like a cool hobby actually. I'll likely try the next one.
I suggest breaking it right off and cleaning off the superglue and use a good epoxy glue. It could save you some cash over a repair.
I have read good things about Bondic plastic weld, but I have had variable success. Back when Phantoms were cracking at the motor mounts, others swore by this stuff.
Reactions: Jntrees
BennieLafo
