Critical battery warning
JNaranjo
Regards,
Taking my drone in the air, on the screen it registers 55% battery but at the same time it indicates "critical battery" I do not understand why, thanks to all!
Happy day
Did you check out your TXT flight log? It might explain what's happening.
Regards,
Taking my drone in the air, on the screen it registers 55% battery but at the same time, it indicates "critical battery" I do not understand why thanks to all!
Happy day
Have you signed up to airdata.com it a site that provides you with info on your flights by giving your feedback on what is happening to your drone while in the air. I had a battery warning come up the other day and the next moment my drone powered off and fell 60 hit the ground with a thud. I checked the logs on air data and they showed that I had two batteries that had a problem of power fluctuations in cell three that the batteries needed to be replaced
Heck
