Dashware Sample from Old Video - February 17, 2019
Is it easy to do or do you have to fiddle with syncing the stuff?
If your video starts at takeoff then not really.
But if you do have to sync, just understand what you should be seeing reading wise.
Raise in altitude and verticle speed = going up in height on the video.
And, there is a track map to assist in syncing motions as well
Very nicely done. I like how you put the compass and speedometer together. Is that gauge available on the toolbox or did you have to custom design it?
It was the one when I opened it for the first time.
The lime green one on the lower corner is in the list of gauges
Which template did you choose after clicking on "New project"?
I started with the Quick Project Creator and it loaded the template by default
But I did do 4 changes
Removed the GoPro logo
Changed the blue track with white
Replaced the speed profile with the lime green multi gauge
enlarged the text/ numerical gauges
Ok. I will check it out. I had saved my template as "DJI Spark" after doing a number of changes and set it at as default.
But after seeing your video, I find this gauge quite interesting and would like to use it.
Would you rather use this instead of using the screen recorder on your iPad?
Syncing the video, data file and also waiting for the overlay to render may seem cumbersome but I like the flexibility it provides in selecting what info we want to show and also the different gauge options we get. A screen recorder would record the entire live view of the Go4 app which is not really necessary.
And I had to figure out that once you save the template with the quick project you have to make a manual project and select the gauge format you saved.
Then you can set it as default and then use quick project again.
Didn't want to create a new thread to show this, but here's another sample I created today. This is the longest distance I have covered on a single charge till date. 6350m in 12 mins.
Reactions: pmshop
ayitsomar
