DJI GO 4
Big Ben
How come on my go 4 app there is no way to adjust the max distance and altitude? On examples I have seen it gives like a 20~500m range. Mine is set on 50 for alt and 100 max distance. With no options. Thank you for any help.
Here's what I see in my GO app:IMG_0609.PNG IMG_0610.PNG IMG_0611.PNG IMG_0612.PNG
Are you using a RC? If not there are fixed limits for distance (100m) and altitude (?).
Looks like indeed only phone and no RC. With phone it is 100m max range.
I do not have enable max distance.?????
Looks like if you are connected to the Spark via wifi. Strange as you have control via the RC.
Maybe you can try a refresh of firmware using DJI assistant with after a reset to factory default ) same menu as firmwares, last entry at bottom.
In any case you will have to do a firmware upgrade very soon.
What functions are N/A for OTG?
Limitations:
  • Cannot change wifi band. In IOS, on android it don't seems correct (looks like a PH3).
  • No signal level indication.
  • Loss of custom buttons setup (for ios devices only).
  • Not officially supported by dji, so it could be removed.
  • Some says that RC cannot be calibrated ? (not checked)
  • RTH maximum altitude is 50m (not checked)
  • Shows the Joystick/GUI button at bottom left (not checked)
1StCoastMavic4
