Firmware
No.
Then just run everything on your current firmware version.
DJI GO will display an inconsistent firmware message if the battery firmware needs to be updated. If you see that message, you should proceed and allow the battery firmware to be updated.
Yes again.
Thanks. Also assuming that if you go fly and run out a battery. Put in a second battery and run that out. Put in a third battery and run that out and never get a firmware message, your batteries are fine.
DJI GO will show that message as soon as your Spark connects to DJI GO if the battery firmware needs to be updated.
Reactions: Wingman8209
Doesn't have the 3x charger from the FlyMore Combo an usb port? Maybe its possible with this at the computer?
Edit: Seems to be just for the charger....
Intelligent Battery update
LynI816428
