Like to know why I get a gimble overload every time I use sport mode ..Does this happen to a lot of you guys out there?And is there anything you can do about it?
A friend had a similar warning caused by an
add-on sunshade. At high speed, in sport mode,
it "seems" to concentrate and/or create an airflow
on the camera. He had warnings with wind gusts
too with that sunshade on.
I did have that problem of overload in normal mode but used some CPU dust-off to clear out any "stuff" that might be causing friction.
My problem is when I slide Sparky left or right the gimbel doesn't stay horizontal with the horizon. My video then tilts to the side, but when I hold Sparky in hand with power on it stays level if i tilt it. ????
