How can I turn the camera while flying?
danilo1
I know that I can tilt the camera through gimbal settings by pressing 100 times up or down to get a slight tilt but I cannot find how I can tilt the camera up and down while flying. The only way I am able to do it is in the QuickShot while it is circling around an object, for example. I want to be able to reproduce this circling but in a normal mode, how can I do it? Many thanks
You must be using the controller and Go4 right ?
Check the manual here for info . . .
Page 36 show the diagram for the gimbal scroll wheel (item 12), and the function button (item 5) can be used to bring the gimbal from straight ahead or 85 degrees down by pushing it forward or back to alternate, very good for quick shots below, and bring it back up to dead ahead.
The DJI Go4 manual can be found online, helps check / set up function button, I found mine set up already for the fast gimbal change.
You can also adjust gimbal speed on the scroll wheel, for more cinematic changes to gimbal speed (less jerky movement).
The Go4 manual
cliftonmatthew45yaw
