HOW LONG SHOULD IMU CALIBRATION TAKE
DAN PORAT
West Lafayette, Indiana
hello.. I have had about four flights...and had not calibrated my IMU.
so, I began it....the blue bar went about 95 percent and quit....
How can I complete the process.
I do have my iphone hooked up to the controller as well....... it moves almost to the end....... and for about 40 minutes
otherwise everything else is groovy!
please and thank you
dan
west lafayette indiana
I didn't calibrate imu, never, because never was asked to do so.
My spark was factory calibrated, and is stable enough.
I believe I had the same problem and fixed it by repositioning the aircraft:
The on-screen diagram changed appearance very subtle and without prompt near the end. It required rotation to a different orientation to complete the final step.
If you repeat the IMU Calibration and focus on the images closely you should catch the re-position step and complete the process.
Similar problem with Compass Calibration too.
Hi Dan, I grew up in WL... Are u for there?
It should take a couple.minute to complete. When I first got mine, I couldn’t calibrate the IMU... Turned out the picture changed and I didn’t realize it... so it sat there and waited... Don’t know if that’s the issue, but it helped me...
dan
dan
great...what worked was the different position of the aircraft....and then it finished the last few percent.... thank you... I am loving it.
yep live in wl media guy and want to brush up quickly for realtor footage. i already do onhold for businesses...etc..tons of production so i could put the whole package together narrated at all.
anyhow..... all is well and Happy Thanksgiving to you.... have a great day
