I lost video feed at about 500 ft out
Jangles
I've taken my bird out 2000ft so far with no problems, however today I lost video at about 500' I read that the latest firmware killed the otg cable, I have not used mine yet, does anyone know if it can still be used with the latest firmware?
Hmm, don't know what to say. I use OTG with an iPhone 6+ without any issues. I power on RC, then Spark. Wait for the green light on RC, then open the GO4 app, the plug OTG into iPhone, then RC and it connects every time.
I have found that there is a sequence to how you connect otg with iOS. Otherwise it won’t connect. Here is what I do.
1- turn craft on first let it beep and do its thing.
2- turn on controller and let the flashing red light turn solid green.
3-plug in the otg cable and wait for the not supported message to come on and than click ok
4- open dji go4 app and you should be golden
Hope this helps. Any other way it won’t work for me.
Same and I posted this before. The OTG cable only works if you plug it into the Apple device first, and then to the controller.
What is the benefit of the OTG? I own one it came with my kit but two inches of WiFi between controller and remote wouldn’t seem to be a problem. Especially if not supported and you lose telemetry what is the benefit? Thanks in advance.
Reactions: MannyCAM2001
You only lose telemetry with Android. For iOS it works great. However, my iPhone worked great without OTG as well. The only reason I use OTG now is because it's quicker to get up and running. If I use wifi, for some reason the first time my iPhone never see's the remotes wifi and I have to turn off/on the remote, then the iPhone see's the remotes wifi. That was a pain so I now use OTG and it connects instantly.
Pbzhch
