If we had Style control on the Spark...
Ender
Hi !
The hilariously oversharpened JPG's would be better so we would not need DNG so bitterly...
And the meager 25 MBit for 1080p could be enough if not abused by artificial sharpness artifacts...
WIth some experiments i was able to adjust the style parameters on sparky...
See the side by side comparison of a 100% crop, shot at VERY bad light indoors.
Photo shows a wood-panel-wall...
(verified today outdoors in briliant sunlight, same result).
+1/0/0 seems to be the Spark normal setting which is horrible and speaks volumes of DJI's understanding of imaging...
0/0/0 is quite okay although -1/0/0 looks blurry but still contains more info & less artifacts (if working carefully with low-rad USM or better Sharpness you get much better then 0/0/0 in Postprocessing).
But for everyday use 0/0/0 (or + / - 1 for contrast) is great i think. See yourself !
(results for video are the same, although not as harsh as 1080p is already scaled down)
Greetings,
Ender
Good news. I will try it on mine.
Where / how do you make the adjustments?
All I see that can be changed is white balance.
Hi !
To do that you need to patch the APK which is not to be elaborated here.
Lets just say if i work out a smooth version / patch it will be published through the usual channels, not here i fear :-(
I wanted to put up hope for decent Spark Image Quality, i am very happy with Quality now...
Greetings & lets obey the local rules.
Ender
patpower9955
