If I am in USA, as far as I know you don´t need permission from the FAA to fly a UAS for recreation or as a hobby.
Unmanned Aircraft Systems (UAS) Frequently Asked Questions
Do I need permission from the FAA to fly a UAS for recreation or as a hobby?
There are two ways for recreational or hobby UAS fliers to operate in the National Airspace System in accordance with the law and/or FAA regulations. Each of the two options has specific requirements that the UAS operator must follow. The decision as to which option to follow is up to the individual operator.
Option #1. Fly in accordance with the Special Rule for Model Aircraft (Public Law 112-95 Section 336). Under this rule, operators must:
- Register their UAS with the FAA
- Fly for hobby or recreational purposes only
- Follow a community-based set of safety guidelines
- Fly the UAS within visual line-of-sight
- Give way to manned aircraft
- Provide prior notification to the airport and air traffic control tower, if one is present, when flying within 5 miles of an airport
- Fly UAS that weigh no more than 55 lbs. unless certified by a community-based organization
Option #2. Fly under the FAA's Small UAS Rule (14 CFR part 107). Under this rule, operators must:
- Register their UAS with the FAA as a "non-modeler"
- Obtain an FAA Remote Pilot Certificate
- Follow the operational requirements (PDF) of Part 107
