Map Radius
It is actually the max distance that your spark will be able to travel away from you. The distance and radius can be changed in the settings.
Reactions: Andy-Spark
It is more of an indicative radius with the home point as center than anything else. It is shown so that you can check if there are any NFZs in your proximity.
To be honest I not sure how accurate that mapping is on the app. But you might what to check out an app called UAV Forecast (in the Apple app store) for your phone and it has a real good map showing where you can fly and the NFZ's around you or at whatever location your at flying. I use it all the time and I have found it very helpful. Hope this helps! Aloha!
I think I have that one on my phone it says good to fly or not is that it ?Screenshot 2019-06-16 10.43.26.png
patpower9955
