Mass Lighthouse
Use active track and draw a square around the lighthouse and then use the option to circle around it. I've used it to do an inspection of my chimney.
Yeah it used to work exactly like that, but with the recent update you have to choose the subject first before you can select the active track. It's confusing & no explanation until you stumble onto the solution (like I did). [emoji39]
Reactions: RotorWash
This what I ended up with
I learned from Ken how to do it manually.
BryantEnde
