Dan
Danno, do you just turn WiFi off then?
So, the OTG cable is used instead of, not in addition to then; correct ?Otg cable is a better connection between remote and device
Yes. Use cable instead of wifi.Dan
Here is one reason NOT to use OTG: latency. See the test this guy did:Yes. You can turn off the phone's wifi when using OTG cable.
The RC and the Spark have a separate wifi connection to communicate. The OTG cable only replaces the wifi connection between the RC and phone. Less wifi connections equals less potential sources of interference.
I have yet to hear of a convincing argument against OTG now that's it's working on both iOS and Android.
I have a Fly More Combo and want to know if I were to use an OTG cable between my iPhone and the controller; should I (or do I need to) connect my iPhone to the Sparks WiFi?
I observed this on my Spark, and it just didn't make sense how a wifi connection could be FASTER than a cable. But, for whatever reason, it was in my case. The guy above tests latency in all three connection modes (OTG, Wifi via RC, and Wifi direct from Spark with no RC).
"This guy" has surely misled a lot of people with this one and a half year old "test" of his as Andre pointed out and it's pretty annoying to keep seeing this video pop up in every OTG-WiFi discussion.Here is one reason NOT to use OTG: latency. See the test this guy did:
Anyway, just to make it clear in simple words, no one flies the Spark like this "test".
You need to go out, fly your drone and check the difference between WiFi and OTG when the AC is at least 300 feet away.
Repeat the test in different settings. Open field, urban/semi-urban area.
You don't need to measure the latency in milliseconds. Your eyes will tell the difference when you see the live feed.
WiFi surely works, but OTG is better. Just as LAN cables are better for networking or online gaming.
Anyone who says you don't need an OTG cable has simply not flown his drone enough.
I use an Android device too and it is absolutely impossible for me to fly without the cable as the video feed with WiFi is terrible. It looks all good when I am connected indoors but as soon as I go out and fly out to a certain distance, I find that the video feed starts getting poor. It is sometimes hard to tell when I am flying straight but as soon as I yaw, I know how long the live feed is taking to update.That's why I said that test with the AC at least 100m or 300 ft away. There is a general consensus that iOS devices perform better with the Spark than Android and many people are happy without OTG too but to rule out the need of OTG without testing in all conditions and across platforms won't be correct. That's what I actually meant by someone not flying the Spark enough. And most importantly, an OTG cable is available all over the world for less than $10. Why not just have one and not need it, rather than running into a situation where you may need one but don't have it.With my Android devices (I use two of them), I noticed problems with video feed, go4 version related, and an otg cable is not helping with them.
Connection between RC and device, cannot be responsible for poor video feed, while distance increases.
