If I missed the 1st 15 seconds, I would have believed that you have lost your mind! I saw it, you had it figured out. You could fly in any horizontal direction as long as you retain altitude. I’ve seen many Utube where they hadn’t figured it out beforehand & hit cliff faces, towers, & statues. Then there are pilots that assume all the trees in an area are the same height.
