Should spark cinematic
You'd need to do it in post using decent editing software.
To "get Djispark cinematic" you spend a couple of months learning video editing and color grading.
You download the video from your Spark into a separate video suite and then crop to cinema and if desired change the colour base and frame rate.
My first attempt is here -
Did not adjust the frame rate and play with the colour on this one, just took the standard colour from the Spark and the GoPro
Tnx. But would like to know from where the software, is it in the duo app? The djigo4? Coz can't the one I have is different
Not at all, DJI do not provide any advanced video editing solution. Use the common video editors (Final Cut Pro, Premiere Pro, Resolve...)
Nice vid Martin.
Sent from my SM-G610F using SparkPilots Spark Forum mobile app
was using Windows movie maker t noticed that the vid after editing & posting loose Pixs, will try one of this. also had a problem when filming, myb cos I was recording with 5.8ghz & signal after 100mtrs was a disaster. now found out how to set it on 2.4ghz & this morning just went a bit further,done 216mtrs but was flying on houses so had to RTH [emoji16]. will try in better area this ev.
Windows movie maker is very basic. It will make video from your Spark look awful.
hi can someone help me out pls. how can i share vids here? would like to show a video so maybe can get some tips
Thank you for being specific. Speaking for newer Spark users, we don't know what other pilots are using. Bless us with your knowledge, please. Shorten our learning curves and save us some cash.
