Spark imu issues
Djsm33
Calibrated compass then tried to calibrate the IMU but it keeps getting stuck at stage 2 of 5 Any help would be great also does it Matter if it's done indoors or outdoors
It's best to calibrate the IMU indoors on a level surface. Are you doing it like this?
Ah i missed the first movement as i had it laying flat and after 10 minutes nothing changed it was still stuck at 2 of 5 so i should have it facing me first till i get the green light?
It doesn't matter which direction the Spark is facing. The only thing that matters is the side that's facing down. Follow the video above exactly and the calibration should complete.
Reactions: LMTLESS
I also suggest that the surface not be carpet (not sure if that applies to you). I know there were issues like that with the Inspire...but, it would make sense if other DJI products using the same IMU tech would possibly have the same issue.
Mark_long72
