Hey, what percentage do you recommend or have for your return to home percentage and altitute?
I have set mine to 25% but thinking is it safe.
When the spark returns home, does it use sports mode? And obsticles is disabled?That depends on the area in which you are flying, possible obstacles in the area, the distance at which the aircraft is when you get the low battery signal, and, what you do after that signal is received.
Bottom line, "safe" is subjective based on a variety of variables depending on your circumstances at the time.
Thanks
Lol i have but cant remenber,tnx buddyIt has been suggested several times to you that you might benefit from reading the manual. Have you done that yet?
