Sparky Record!
Kindly advice the photo of your drone setup . thank you
The camera was set up on Auto settings except the White balance which was on "Cloudy"; the connectivity was Controller to I Pad Mini with an OTG cable plus signal enhancers on the controller.
Had 10% battery on precision landing!
Reactions: Mark Waco
did u have it on sports mode?
Hi O, yes definitely in Sports mode and in RTH, push full stick forward to get an extra 5 / 10 klms per hour speed, I have done a few range tests and if the wind picks up on the return, I take it out of RTH and manually bring it back using the Map and in Sport mode.
Nice flight and great demo.
Gonna be a shock & a surprise for those pretenders
of the 2.4gh (better range, connection...) !
I always use 5gh. Less interference and, logically,
best penetrating capabilities through light obstacles.
Never had a disconnection, even on a few "test" hops
up to 2km. But I usually keep the bird a lot closer...
Thanks D, next time I will record the screen so will be able to see the Sparks stats !
Awesome flight. The video would have looked even better with the telemetry data overlayed on it. Try it next time.
bornzero2none
