Where is the map window ?
GDN21
Dijon Burgundy France
When i'm disconnected form the spark and i launch Dji Go 4 last version i have a map that i can see where i'm located. When i connect the spark and hit Go fly that map disappeared ? Didn't find a configuration menu to hide the map...i missed something ?
@GDN21 do you mean that tiny little map in lower left corner of screen? I think it's replaced with tiny "videogame map-like" circle that shows compass orientation of your bird and your homepoint. If you want to view actual map miniature, tap the circle I described and it will switch to map.
How do I get one of my Function buttons to toggle the map ?
I set it up in the settings but nothing happens
The map came back after firmware update strange ... no the compass window is another one i have the two
Sohan hridoy
