Hi!
This is for you log-grinders out there..
First of all, nothing unusual drone behaviour in flight.
No warnings on screen about battery voltage. So I didnt notice until checking uploaded log at phantomhelp.
Usually I use Airdata, and viewing the log there shows nothing about battery voltage abnormality!
This is the log: ---> DJI Flight Log Viewer - PhantomHelp.com
- Log show some abnormal battery voltage readings. Should I be worried?
- Also, RTH was set at 30m successfully at startup. When RTH was initiated I was about 100m. RTH was performed at 100m altitude. Does this mean if you're above set RTH height, it will not decent to RTH height, but just return to home at current altitude?
