Aftermarket replacement rotor blades
FastR
I'm curious if anyone has used aftermarket replacement blades from eBay? I'm interested in possibly replacing mine with a colored set but I'm leary about them. They are a lot less expensive than the dji blades and I've always been one to follow the rule of you get what you pay for. Had anyone tried them? Are they durable?
I got some off of Ebay and found them stiff to open from the closed position but my Spark had no problem opening them. Then i ordered some from amazon and found them to be exactly the same as the DJI ones . If they are not from the same supplier as DJI they are perfect replicas . I even took a loupe to look at them and i find no difference , so yes i'm using some but i'm not a experienced flyer but if i would try to do a distance flight or extreme altitude flight i would not hesitate to put my original DJI blades on.
Some good reading here .
Anyone use NON OEM props?
I use some now on most every flight from eBay am Amazon the 4730F is the ones I use if I’m going in sports mode r range I use DJI
over all they r cheaper but works great for my lil beast
I made a thread about this if you like to find it, I got some yellow blades and there is no difference at all. As for the blades being a little stiff to open, just open them yourself, again many discussions about this.
d beard
