Best Glue
Mrmund
My Spark frame has a crack in one the arms that I need to repair for use until the replacement frame arrives.
What's the best glue to mend the grey plastic
J-B WELD Clearweld Clear Epoxy Adhesive. or the original J-B WELD (gray in color ) that i have used and i know it works .
any Epoxy will most likely bond and keep you flying .
if you showed us the crack we could say one way or the other if maybe you would not even need a new frame . make sure you give the Epoxy at least one full day to cure .
that's the worst place for a crack . J-B WELD should hold but in that spot i would just wait and change the air frame .
New frame ordered, need it for a quick project tomorrow night.
I'll change out the frame when the new one arrives net week
I've changed a few drones air frame's if this is your first change frame to frame the one thing i will tell you is to take photo's a lot of photo's , step by step . you can always go back and check the photos for the wiring . there are some videos on you tube to look at before you start .
Reactions: Mrmund
It will be my first time opening up a drone so I appreciate the advice
RudyTiegs
