Remote ID add on
The Holy Stone and Ruko are the most commonly used RID modules. Both are priced right too.
Reactions: Rob's Red Spark
Hey gang! I was wondering if there's a Remote ID module that seems to work best for the Spark?
Thanks in advance!
Hey! For the DJI Spark, you'll need an external Remote ID module since it doesn’t have built-in compliance. The DroneTag Mini and Dronetag Beacon are solid choices, compact, reliable, and FAA-compliant. The Bluemark DB120 is another good option with a simple setup.
Just make sure whatever you get meets FAA Remote ID standards and can be securely mounted without messing with your Spark’s balance. Hope that helps, fly safe! 🚀
akane13
