Can't Fly Higher
JPY
I can't seem to fly higher than 4-5 metres. It will say: "Maximum Flight Altitude reached" Why is this happening?
Are you in beginner mode?
If not, there are settings in the Go4 app to set your maximum altitude.
Reactions: JPY
Come to think of it, that happened to me once and all of my settings were correct.
I started the app over and it was okay after that.
I'm sure you've done that already?
Reactions: JPY
I think I've figured it out: tried it in another location and as soon as it says "The homepoint has been updated" it starts to ascend higher than the 5 metres limit.
Yes, there is a cutoff based on the wifi strength of the mobil device. If you go into your settings it should be locked both ways distance and altitude. Don’t remember exactly, since I use an RC. But DJI states the max altitude around that high.
Dmizzoni
