Chinese props
sickno
Hi guys,
Does anyone has experience with thirdparty props? I did see some non dji props, what looks promising but to cheap to be true...
I don't know exactly why you would specify "Chinese" props? Where do you think the originals/DJI props are made? The whole thing is Chinese!
But, to address your concern about cheaper/aftermarket props for the Spark, I have been running a set that I got from Amazon:
www.amazon.com/gp/product/B077NYX3X8/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
These have been absolutely no trouble or difference from OEM at all and I will buy again. I like the red on the front to help with orientation.
Hi guys,
I have and suggest don,t bother luckily for me they wouldn,t even get the drone more than a few feet up, it does a crazy little dance
Reactions: Reed Adams
What i ment with chinese props are offcourse alibaba/wish/aliexpress props
I used some i purchase off eBay that works very well on my third set will order more I use the 4730f they are cheaper but they also have 4730S
Reactions: ZPFunk
I got the red ones by Anbee and my Spark had erratic behavior. Then it didn't want to land. It hovered about 4 inches from the floor with stick full down for about 7-8 seconds before it landed. I took them straight off. They are lighter and more flexible than OEM blades.
Yes, I just weighed them to .00 g, they are within .02g. The 2 originals I have left were farther apart then all 8 in the set I received. They snap in place and lock securely just as the originals. In flight tests I was giving it a good workout around our flying field in sport mode, max speed was no different than before, no wobble, no ill effects.
Reactions: ZPFunk
Thanks for the info Bob! I'll be ordering some!
