Code d
drews drone
I went to fly my spark today and a code d came up saying I was in a restricted area how do I find out the rules about flying in this area
Reactions: Rob1arri
The app AirMap will give good indication of where you can fly in the US based on a selectable rule set of 336 (for fun) or 107 (licensed).
Ok to fly machines under 7kg in Cat D airspace. Download the NATS app it will show you all the areas and categories
Sorry yes class D and it was in England
Short answer - you’re fine, just follow the drone code. If you start flying anything above 7kg, you’ll need to notify the CAA.
For info;
Taken from the CAA website -
CAP 722 UAV operations UK
1.36 Under ANO 2009 Article 166, operators of SUA with a mass of 7 kg or less are not required to gain an NSF approval from Air Traffic Control (ATC) to operate within Class A, C, D or E airspace or within an active ATZ. However ANO Article 166 states that a person in charge of a SUA ‘may only fly the aircraft if reasonably satisfied that the flight can safely be made’ and that they ‘must maintain direct, unaided visual contact with the aircraft … for the purpose of avoiding collisions’.
Reactions: FLYBOYJ
1StCoastMavic4
