Looks like you have some great connections going there. If I get more then 1000" away I start losing it.
Hoping the new OTG update may help that..
I am going to have to look into the Litchi, sounds promising.This is ran with Litchi Beta 2.5 Katt
They enabled Waypoints and Orbit.
The flight plan is loaded to the spark.
If it loses RC contact, it continues the mission.
I lost contact just ober that Cross Mountain and regained about 1:15 of the video.
Nice video. I am particularly impressed with the smoothness of the yaw. Did the waypoints improve the yaw of the spark, or did you use a warp stabilizer?
I agree. Just a slight touch to the stick...good look
I lost contact just over that Cross Mountain and regained about 1:15 of the video.
I would love to know/understand how that mission continues after the RC contact is broken.... so one would imagine you are only limited by your battery in terms of time/distance when autonomous. Is there any algorithm in Litchi that can gauge in advance your available distance via waypoint against your battery potential? Or is that human calculation in advance? Guess I better go watch some YT too!
I have not had as good an experience with Litchi. In the past, I used it to provide FPV with goggles on the Phantom 3 standard. I found it to be inconsistent in performance, so I abandoned it. I later learned that we need to force stop (android) the DJI Go app to prevent conflict of control. Maybe I'll revisit using LitchiActually, This was an automated mission.
**Litchi Beta 2.5 added waypoints and orbit to the Spark.
Litchi provides curved waypoints (not to be confused with spline waypoints).
These curves can be adjusted to how tight or relaxed curves you want.
Example: the curve at 0:17 - 0:23 was a combination of 2 waypoints 500ft (152m) each...end of one and start of another maybe 50ft (15.25m) between the two.
