Dji Googles with spark
The DJI Goggles are not able to connect to the Spark wirelessly.
You could connect them to the HDMI output on a mobile device like the CrystalSky or NVidia Shield K1. And if you're flying via Wi-Fi with an Apple device, you can connect the goggles to the Apple device using a Lightning to HDMI adapter (like this one).
10206
Somos de Argentina y muchos usuarios pueden volar en Spark bajo LITCHI APP Principalmente con el modo al WAYPOINT o misión de vuelo bajo GPS
Al aire libre . These are the best way for send Drones fron home to big distante without risk, and ir can return to home without touch the RC But firstly with all setup previwsly under DJI go4
Do the dji googles work with the spark
Of course you can. But not through wi-fi connection, only in combination with a remote controller, connected through an OTG microUSB to microUSB cable (like the one provided with the controller, but longer, so you can hold the remote at arms length).
And you can only use a few of the smart flying modes (tap to fly, tripod and active track). Also, due to the limited number of axes of the Spark gimbal, you can only look fwd or down with it in head mode control.
