I’ll do it and try again. Thank you SO much for taking the time to help me! I was starting to want to write in the classifieds sectionFormat the MicroSD card with this - defaults as installed - and try again:
Using SD Formatter Tool to restore full capacity on SDHC/SDXC cards
You will see "glitches" with the Spark.
But they are more of a frame rate issue when panning.
Pan slow enough to avoid the jumpiness
I'm using the one that came with my Mavic...you think the card is the issue here?Try different microSD card.
SD card, uploaded them directly to dropbox.Where did you take these videos from? Sd card or cache?
And also, I noticed your second video would only display 720p, I would have expected 1080p as an option.Does the raw video play fine downloaded from the Spark's sd card and run on your computer? The issues I've come across with jerky video is when I've trans-coded video with settings not compatible with the Spark. Your video almost looks like it was uploaded in a lower resolution, then up-scaled by YouTube to high res.
Not really. It looked like trash on everything I viewed it from. I'm going to reformat the SD Card and try again here pretty soon.Does the raw video play fine downloaded from the Spark's sd card and run on your computer? The issues I've come across with jerky video is when I've trans-coded video with settings not compatible with the Spark. Your video almost looks like it was uploaded in a lower resolution, then up-scaled by YouTube to high res.
So strange. I shot with the Spark. I'm going to reset and reformat both the Mavic Pro, and the Spark and get out and try again. I think this Spark is buggy anyway and am about to put it up for sale.And also, I noticed your second video would only display 720p, I would have expected 1080p as an option.
So check this out - I think I have it figured out. I evidently uploaded via phone (I do so many uploads I forget how I do it). From now on, I'm going to upload direct from the card or by plugging the drone into my MacBook. So I extracted some video directly from plugging the USB into the computer from the drone and the difference in quality was like that of a Jaguar to a Ford Focus. (No offense to any focus drivers in here) but man this is exactly what I was looking for. I'm gonna play around in an editor and create a new video using the most recent quality uploaded video and stick it on YouTube...then share the link here.Sorry Dan
I only looked at your video on a small screen the first time. If that's not the SD card then it's your Spark. But one other thing to try, swap out the propellers or checks for something loose. This may be the Spark trying to remove jello.
