Flight records only from Spark, no phone
Marossik
Hi all. Is there any option how to get flight records from Spark to application when you fly only with RC or gesture control? I miss them for total statistics. I have results only when flying with phone connected. :(
If DJI GO is not running, a TXT flight log is not created on your mobile device. However, a DAT flight log is always created and stored on the Spark's internal memory card. You can retrieve the DAT files like this.
Reactions: Stef and Marossik
If the question is can you get your flights to appear in GO4's flight logs, the answer is no.
Yes. That was the question. :) I think that converting FLY...dat files from Spark to txt and/or somehow importing to directories of GO4 app could work.
Can you fly a Spark with the controller without a phone attached? Obviously no Go app running, so how do you know if it is picking up satellites or what mode it is in?
playzen
