GPS Tracker or something similar for fly aways
have your friend hide it in a large open tall grass field. you will see the problem ;)
The tile has an advantage here in the "last mile" (last 30 feet actually) of the hunt, in that your phone can give you a fairly good warmer/colder indication and you can use that to get within a few feet of it, once it's in range of the phone. Before that, it will be no help at all. Here's what it's all going to come down to: If you can use your flight log to get yourself within a few hundred feet of the spark, the tile WILL lead you to your spark, almost guaranteed. The challenge is getting that close to begin with.
If you can do that using your flight log, that combined with your tile will make a great recovery system. if however your flight log isn't being helpful, you'll have a big problem trying to get close enough for your tile to register on your phone. This is a BIG problem with a fly-away, because the spark will continue to fly who-knows-how-far after you have lost contact with your spark and are no longer receiving new position indications to record in your flight log. The best you can do is walk the line it was headed in from the point it was at when you lost it and hope you stumble on it shortly down the path.
An independent GPS tracker can provide a backup location indication, that will get you within probably about 10-20 feet of the spark. From there you will be on your own, but hopefully you can scour that small patch and find it. This position indication will continue to update even after your spark has landed and powered down. As long as it has cell and gps service, a fairly precise location will be available for you in the cloud and you can just walk to that spot using your cell phone as a gps and start looking for it. Theoretically a GPS tracker combined with a tile would be a really good combination, but getting in the vicinity of the spark is clearly more important than speeding up the final search.
If it gets hung up in a tree, that will greatly improve the tile's range if it's near the ground, otherwise it will provide a weaker signal over a large area and not give you any indication it's 60 feet above you, probably tricking you into spending a lot of time searching the bushes below. GPS will give you elevation in addition to x,y so you will know if you're treed or in a rain gutter on a roof etc.
(FYI I have extensive experience in radio signal tracking, I do most of my hunting with a homemade Roanoke Doppler)
I purchased one of these.
Upgradable to 4 tiles.
Only used it on "Hide and Seek" testing around the backyard.
My copilot would hide the Spark and I would find it. And vice-versa.
It works off of RF frequency with it's own tracker and is better than Bluethooth with 400' LOS range?
GPS tiles may require a monthly fee to stay active?
Can you post a better picture of the Spark with the locator on attached? Thanks.
Is anyone using any other extras like GPS tracker for the spark in case of fly aways?
I use the Marco Polo rc Tracker and here is how I installed it
Here is a hide and seek test I did with it
might be wrong but think it is bluetooth and only about 100ft range.
You're correct. The original Tile only has a max range of 100 feet.
The Tile Sport (and Tile Style) has a max range of 200 feet. This surely wouldn't replace a GPS tracker, but it could come in handy if you land/crash in a field of tall grass and are able to get within 200 feet of your Spark before you need to start hunting it down.
According to some tests seen on YT, the Tile Style/Sport can operate up to 500 feet away.
