Histogram and OSD setting
MR2 LANDO
I am new Spark and Go 4 app user. I was trying some of camera settings and turned on the histogram and OSD by sliding the control bar to green. Now they stay on the display screen all the time. If I slide the control bar back to gray they still show up on the main screen. How do you turn them off again ? I would like to not have all that extra information takin up all the space all the time.
That sounds like a software bug. Toggling the histogram off in Settings should obviously remove it from the screen.
Did you install the DJI Go app update that came out this week?
Options:
1. Install latest update
2. Wait for next update to fix it
3. Uninstall then reinstall app
4. Roll back to prior version with DJI Assistant
I actually have the opposite issue. The histogram disappears every time I swap out the battery. I wish the "on" setting persisted when power is cycled like so many others. I use histogram constantly because screen not accurate exposure from sun glare.
I used to lose the histogram and OSD every time I left the Go app with no battery change, although I must admit there have been 2 or 3 updates since I last checked.
With my Mavic Pro the histogram stays on until I manually toggle it off -- even with battery change and app switching. It would be simple software patch for Spark to do the same. I just sent feature request to DJI Support
Reactions: Tglass0000
Pbzhch
