Is It Worth Using A OTG Cable On The Spark?
Martinhc
I purchased an otg cable trying it on my note 4 Samsung device, But I find myself using the wifi anyone else using it?
aviscomi
Philadelphia, PA
It should also be noted that DJI does NOT support the use of OTG, though others will soon reply with "back-door" methods.
Paul215
Germany
My reason for OTG is that I'm using an android phone and live in europe. If you want to keep legal and use CE mode you have a pity range. Second problem is that androids can't use 5,8ghz. So normally the only way is to use 2,4 ghz for phone and 5,8ghz for drone connection. But 5,8ghz + CE mode = range under 100m.
With otg cabel I can use 2,4 ghz for the spark and get a range around 400m.
Alexeyssautier
