Led lights
Big Ben
I love night flying but the spark just doesn't cut it when it comes to lights. I have seen those flashlights you put on the landing gear however I'm not looking for flashlights but for bright *** led lights to see for a good distance. Any ideas?
My bet is that it's just a matter of time before STROBON Cree Strobes are made for the Spark.
They're easy enough to attach with adhesive Velcro strips. (I also put a THIN strip of Gorilla tape across the middle as extra security.)
I get them from STROBON Cree LED Strobe Light - Phantom Help
What I do is put a red strobe on the front, green on the rear, and one white on each side. This way you can tell the exact orientation of the Spark. I tested these on my Mavic out to 2 miles. You could still see them, but after a mile the colors start to all look like a blueish-white -- but still visible past 2 miles.
You'll love it. When you fly at night at 200 feet it looks like a real plane going by at 2000 feet.
Most countries it's illegal to fly at night? (So probably why they haven't really considered improving the LEDs)
I agree though, LEDs we have aren't really that great... particularly I think the flashing sequence is too long.
Most countries it's illegal to fly at night? .
Yeah we're lucky here in the US. If you're flying as a hobbyist, night flights are OK. Commercial operators need a waiver.
It may seem counter-intuitive, but flying at night is much safer with the proper lighting system.
- Your AC can be seen for 2+ miles so keeping it VLOS is not an issue -- how far can you fly the Spark during the day before you lose sight of it? :-)
- In suburban areas, there is generally much less traffic and people out so there's less risk of property damage or injuries.
- No Sun = No glare on the screen & no heat issues, aircraft runs cooler, more comfortable for pilot (just wear bug spray!)
Reactions: shaynemcmurdo
And what about battery life? If on a Phantom we can rely on a relatively big battery, the flight time of the Spark is quite short already. Wouldn't a powerful led system shorten it even more?
Did you look at the link to the light listed above? These lights are self-contained with their own (rechargeable) battery. They run several hours so you only need to charge them every other day or so.
Weight could be an issue for the Spark's battery but it is only 4gr, so if you put only one on your Spark it will be negligible.
You can put several on the Spark and it won't matter.
5 will be at the cost of one minute, so yes, 2-3 should not be a drama.
Is there a way to switch the Strobon so the light is constant?
playzen
