- Join
- Jan 6, 2019
- Messages
- 55
- Age
- 26
Just flew them, definitely quieter, a little more responsive. Next flight will concentrate on time first with old props then new .Getting my new stealth props tomorrow.
Good to know, thanks for the update. Do the Stealth props have much difference from the OEM in pitch or flexibility?hi all
just received my Stealth prop's and not happy, noise almost the same as the originals, but the sound is different, less harsh on the ears, but will not use them, as the motors became very hot using the Stealth prop, i have switched back and forth between the original props, CF props and flew for 3 min each time with a different set, when you touch the motors after 3 min the originals and CF very little heat, after the Stealth, almost untouchable, so 4x props for the showcase, what a pity, i enjoyed the different sound
great very happy for you, at least you did not waste your money like i did, Stealth props now very expensive showcase ornaments,Got a chance to test them out today here is my review
-Lower pitch so a bit less noisy
-no issues at all with hot motors like stated above and I ran two full batteries through them with a mix of sport mode and with obstacle avoidance off speed. They were the same temp as the with the stock props
-I would like to say I got longer run time one battery I got 13min in the air which is about normal for me. The last battery I got 14 min in the air that is the longest flight time so far.
-responsiveness is the same I would say it wasn't any faster.
-I feel these will last me another 100 flights (the stock first set of props lasted me 100 flights and still look good)
And all of the above tests were today in 90 degree hit with an altitude of about 350 to 400 ft with wind gusts up to 33mph(at 300ft as per air data). So I would say I gave them a pretty good test and they performed great.
Let me know if you have any questions.
What can i say,testing the stealth props heated up the motors running then indoors, i was not happy, finally had the opertunity to fly them outside, and no heat on motors, flew up to 12min on 1 batt, and the RC responce is great,why the motors run hot inside no idea, but outside they are superior,i will defintly order another setI agree with NJSpark,
Less noisy, useful in "urban neighborhood"
Longest flight time (on sport mode)
Motors temperature seems same as OEM props.
Still have to test about vibration with long exposure
shots on my next "very late afternoon" flight...
Yes, botton line the Stealth props is realy awesome, control lot more responsive and i actualy managed 11min in the air,small improvements but worth itMaybe because your moving outside and air is rushing over them.
