Need help
Hey and welcome... ATTI mode or attitude mode happens when the Spark loses GPS positioning. It will hold it's altitude but drift around in the wind. If this happens, you should immediately raise the Spark above all surrounding obstacles and try to regain GPS or land it once you get control.
If this keeps happening in different areas you fly from you may need service.
Always make sure you have at least 10 satellite before taking off otherwise you might end up in ATTI mode. If you have flown other drones which don’t have GPS, you will probably find It is no problem, but if you’ve never flown a drone like that, you may find its a little scary at first.
Always check your IMU and compass for interference by checking the sensors every time before you fly . If your sensors show a lot of interference, move to another location, or fly another day .
It never goes passed 5.8
a poor compass calibration can cause any DJI UAV ro revert to ATTI mode. So recalibrating the magnetometer could solve a frequent ATTI mode warning.
Reactions: Doma
