No back video
alexandreM
Hello, I have a problem with the back video, I have a dark screen on my phone, I can't see what the camera take, but when I want to take a video, this video is on the memory, but I can't see what i'm filming
Need help
If you say you have a dark screen, do you mean that all other information about the drone (battery, gps, position) is visible. You only miss the video feed? What if you switch to camera-mode and just take a picture?
Yes I only miss the video feed but even if I switch to picture mode I have a dark screen but I have all the telemetry
Need help
The actual video is on the sd?
Ios or Android device?
Cable or WiFi connection between RC and device?
I would try to connect without cable (WiFi), with another cable, and if these failed I would try with another phone.
It's not necessary for your phone to be on this list, to operate without issues.
But go4 is a "heavy" app, so you need a modern multi-core device.
It is good to fly in airplane mode, and with any other task closed. During flight your device must be dedicated to your drone needs.
Ok, thank you, I have a huawei p8 lite 2014, if I put the phone in airplane mode, the cnonnection will be good ?
1StCoastMavic4
