Oops Anaheim Ca
KevTN
Chattanooga, TN
Just flew into LAX for my daughters last travel softball tourney. Brought my spark along and dang it I forgot my charger. Not wanting to buy a hub. If I can find the cable somewhere would it work off a USB hub? Or any other suggestions?
Thanks...
Dummy
I talked with DJI they said I can use my usb to micro to charge. I am going to give it time but I don’t see the battery lights light up. I am hoping/guessing it is because it isn’t hooked up to a DJI charger...fingers crossed.
I've found that for certain devices, such as the Spark, some micro USB cables work while other identical appearing ones will not.
If the battery doesn't start till blink within a minute keep trying different cables. The thicker and brand name ones are most reliable. When you find one that works mark it with some tape and add to your accessory bag
