P.A.F
dji_lando
So i got my Venom(Spark) 2 weeks ago and today i was going through the app and saw the P.A.F button while i was using the otg, but when not using otg , the P.A.F does not appear in the settings. So my question is , can anyone tell me how the P.A.F works and what it is for?..thank you
There is no way to manually switch the flight mode with the Spark. It always flies in P mode by default. If GPS is not available or it experiences some kind of issue where the GPS data cannot be used, then it'll auto switch to A mode.
OTG is not officially supported by DJI for the Spark. Different things happen or appear on the screen when using OTG depending on your device, firmware version, and DJO GO 4 version.
Bottom line, I'd give up on OTG until/if it is ever officially supported.
Its an on and off switch for the P.A.F....should that be on or off?
Multiple flight mode should be enabled. You're only seeing that setting because you're connected via OTG.
Reactions: dji_lando
Dmizzoni
