If I launch my Spark from the ground using the RC, can I Palm Land it it or do I have to be in Gesture Mode first?
You have to switch to gesture mode when landing. Or you can program one of the buttons on your RC to take off & land. I have the button on the RC set up this way & just fly back put my hand under the spark as it's flying, push the button on RC & it lands in my hand. No need to switch to gesture mode this way.If I launch my Spark from the ground using the RC, can I Palm Land it it or do I have to be in Gesture Mode first?
Thanks, very helpful. What setting do you use on the RC button?You have to switch to gesture mode when landing. Or you can program one of the buttons on your RC to take off & land. I have the button on the RC set up this way & just fly back put my hand under the spark as it's flying, push the button on RC & it lands in my hand. No need to switch to gesture mode this way.
Take off & land. You have to scroll down in the app settings to make this choice when programming the button.Thanks, very helpful. What setting do you use on the RC button?
I have had my custom button setup to take off & land since I started flying & have never pushed the button accidentally. Kinda like a gun keep your booger picker off the bang switch until it's time to use itHave you ever hit the "land" button accidentally? A significant part of my flying is over water so I was wondering if that would be an issue.
I also hand land using the remote all of the time without using gesture mode or the landing slider. The spark will initially try to move up and away from your hand, but with a constant down stick, it typically rises just a foot or so and then settles back down into my hand.
