Panning help
twickers14
SW U.K.
Hi all. The pic I took below is of Ashton Court here in Bristol UK. Some good flying weather at last! I also took some video which is nice but what I really wanted to do was pan right to left. Is there one of the Intelligent Flight Modes I can use that will achieve that? Otherwise I guess I have to fly it manually-bit of a faff and even though my gamble is set at 10 and I have used Tripod Mode there are still jerks in the shots. Help very much welcomed.
Not able to understand what you are trying to do here. Why would you use the gimbal if you are just rolling (panning) from right to left? The gimbal speed setting is for the pitch axis. You have no control on its rolling.
Anyway, if you are looking for an automated mode to shoot that building, I suggest you go into Active Track mode, select the building and use the slider on the screen to make the AC revolve around that building. Make sure you select a slow speed and the shot will come out really good.
Reactions: oleflyv
Sorry only mentioned the gimbal in case I wanted to drop or ascend during the pan keeping the subject centered. Great advice and will go and try it. It is a big public building so not sure I can circle it but will see what I can achieve. Thank you for your help.
Heck
