Photo issues: thumbnails
Hello!
When I went out today all of my photos saved to my phone as thumbnails that were really small, not full sized pictures. Any idea why this may be?
The thumbnails are cached images and are not worth posting.
The good stuff is on the SD card.
You can open up the Go4 editor and review your pictures while the Spark is powered up and connected.
I usually do this after landing and the Spark is resting as I look at the pictures I took, If I want to save some to the device, there's an option to do so on each image and it will transfer via WiFi.
The other option is to remove the card and use a PC for file transfers.
This makes sense.
Thank you!
Hi Marcus, Please check photos on your PC or laptop. Also update your phone then check again. I hope all photos are correct in the same size;.
fulavio
