- Join
- Aug 20, 2018
- Messages
- 30
- Age
- 72
Did a first today and turned the mike on. Th audio was there on the smartphone but not on the Spark's SD card. How do I do this?
You'll need to use some type of video editor to combine the video and sound files.How do I do this?
The sound is recorded to the video CACHE which is only on the phone. So if you want to use that audio on the edit you must also use the low quality video from the cache.
I had considered that option but could not figure out how to extract the audio file separately from the video cache file.
What is the name of software and steps you take? Have you actually done this or just theoretical?
Would be very helpful if you could explain
I use Apple QuickTime to export the audio from the low rez footage. Then import into video pad. Viewing the audio waveform, you’ll see a “spike” where the clap sound is. Then line up the video of hands making contact with the spike and your in sync.
